When combining different mesh files from different mesh cells into one Fluent cell, Fluent assigns ‘solid’ type to all cell zones even though these were designated as ‘fluid’ in meshing. How can I change this behavior?
Tagged: 18.2, fluent, fluid-dynamics, General, General - FLUENT
June 5, 2023 at 7:06 am
FAQParticipantToo keep Fluent from assigning a ‘solid’ type to all cell zones, use Named Selections in meshing and give a the fluid zone names a prefix such as ‘fluid_’ to these named selections. One this is done, Fluent will assign ‘Fluid’ type to cell zones.
- Skewness in ANSYS Meshing
