When attempting to compile a user Fortran shared library on a Windows machine using the Intel Fortran compiler, a failure occurs with the error message: ipo: error #11035: Fatal error cannot open ifconsol (NOTE: The same message may relate to libraries other than ifconsol.)
March 17, 2023 at 9:01 am
FAQ
ParticipantThe most likely cause is that the ifortvars script has not been run prior to running cfx5mkext. It is necessary to run ifortvars every time a new command window has been opened in order to set certain environment variables used by the compiler. The procecure is as follows: – Start a new command window from the CFX launcher (using ‘Tools > Command Line’). – Type the commmand: ifortvars – Run cfx5mkext
