When adding new Queue to RSM v18.2 and attaching that to hostname there is an error “Exception processing operation arguments:: Error parsing machine argument.”
April 5, 2023 at 2:32 pm
FAQ
ParticipantThis is a known error and comes up when Hostname is “alphanumeric” (example: 4HS67Z1). To move ahead you can use IP v4 address of the machine. to see IP v4 address, use command ‘ipconfig’ (without quotes). The issue is resolved in RSM v19.0
- Q: How do I set the license server from my client machine?
