When a transient CFX case (.res and .trn files) with moving geometry (for example a transient turbomachinery) case is loaded into EnSight, the geometry doesn’t move/rotate with time. Why is this happening.
March 17, 2023 at 8:58 am
FAQ
ParticipantThis behavior can be changed with the following steps in EnSight. 1. When opening a case, select Advanced Interface. 2. Open the Format options tab 3. Set Transient Geometry? = Yes (Coordinates only) 4. Load all parts
- Skewness in ANSYS Meshing
