When a cut-cell mesh is used in Fluent, what interpolation method does Fluent use to get the cell center & cell surface values for the larger element?
May 15, 2023 at 8:32 am
SolutionParticipantPlease refer to attachment to access the solution. Keywords: cutcell, interpolation
1. 2054981.pdf
- Skewness in ANSYS Meshing
