When a Creo surface part is imported into SpaceClaim I get the following error: “No B-Rep data in input file”.
June 6, 2022 at 10:33 am
FAQ
ParticipantAll CAD models are b-rep data unless it’s faceted data. B-rep means boundary (face) representation Usually when we see this the file size is very small and no supported data was saved to it. For example, the surfaces in Creo are hidden and aren’t being written to the file.
- ANSYS DesignModeler: How to Perform a Clean and Repair
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: Weld Feature
- ANSYS DesignModeler: Shared Toplogy
- How to move component within the assembly?
- ANSYS SpaceClaim: Shared Topology
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
- ANSYS SpaceClaim: Imprinting Geometry
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
