What values should be used for the Reference inlet temperatures in the ungrouped macro heat exchanger model..?
January 25, 2023 at 7:16 am
FAQParticipant1) The Reference Inlet temperature values are required to calculate the NTUs and effectiveness matrix for the heat exchanger for the heat rejection data table provided 2) the Reference Inlet temperatures for the Auxiliary & Primary fluids are the inlet temperatures for both the fluids, at which the experiment was performed to achieve the heat rejection data table
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
