June 6, 2022 at 9:58 am
FAQParticipantVFSM can be used to force the view factor matrix rows to sum to one. This should only be done when the enclosure really is completely closed.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
