What to do when Bonded Contact does not seem to work with Frictionless Contact? Why bonded contact does not look to working with frictionless contact?
Tagged: 18.2, General, mechanical, static, structural-and-thermal, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantFor sample case like a small washer area that is bonded adjacent to frictionless contact. In such cases, using default Program Controlled algorithm, the contact may not be established properly. To resolve it, using MPC algorithm for the Bonded Contact can help.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
