March 17, 2023 at 8:58 am
FAQParticipantIf the Enclosure fails, you might get a message such as: 8 bodies could not be subtracted from the enclosure body. In a such case, delete the Enclosure, save the case under a different name and try to unite the solids into one. (Design > Intersect > Combine > Merge (all) Bodies) Likely, some bodies will not merge, being clearly visible in the tree. This can help to diagnose the problem.
- Skewness in ANSYS Meshing
