What should be Ambient Temp Type in Imported Convection during 1-way transfer from Fluent to Mechanical?
January 25, 2023 at 7:16 am
FAQParticipantThe convection coefficient uses “Wall Func. Heat Tran. Coeff” (from Fluent) or “Wall Heat Transfer Coefficient” (from CFD-Post). This is based on wall functions and the reference temperature used for this formulation is “Wall Adjacent Temperature” (CFD near-wall temperature). When using Fluent, the convection coefficient will always be based on the wall function heat transfer coefficient so the ambient temp type should always be kept as “CFD near-wall Temperature”. This option is here because CFX users have the option to define the HTC based on a constant value, in which case, the “Ambient Temp Type” should be set to constant to match.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
