Tagged: 19, mapdl, mechanical-apdl, radiation, structural-and-thermal, structural-mechanics, thermal
April 5, 2023 at 2:33 pm
FAQParticipantIn a thermal analysis incvolving the radiosity solver, the presence of sSURF251 or SURF252 element types leads to creation of a rsm file. Issuing CDWRITE or SAVE causes the mapping information to be saved to a .rsm file. See Advanced Radiosity Options (4.7 Thermal Analysis Guide).
