What numeric method is used in the Fluent Stiff Chemistry Solver? Is it operator splitting or something else? What is the order of accuracy of the resulting chemistry source term(s)? Is there a difference in the treatment between the Fluent Stiff Chemistry solver and Chemkin CFD solvers?
Tagged: 19, BCs & Interfaces, fluent, fluid-dynamics, materials, Species/Reactions
January 25, 2023 at 7:17 am
FAQParticipantFluent employs no formal operator splitting method. Instead, the chemistry source terms are integrated over a timescale that is assumed to give them step-independence. This timescale is chosen to be larger than the reaction timescale, to allow for stability, but small enough to produce a step-independent source term. For steady runs, the timescale is 1/10 of the minimum computed diffusion/advection timescale; for transient runs the physical timescale is used. This treatment for reaction source terms is first-order accurate.
- How do I model humidity in Fluent?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Model setup: Setting up chemical reactions
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
