June 5, 2023 at 7:04 am
FAQParticipantForce reaction in a plane strain model is force/unit thickness. The thickness is the unit length of the metric you are using in Mechanical.For example, if you use meter in Mechanical and reaction force is 5 N, then the reaction force is actually 5 N/m.
