Tagged: 17.1, fluent, fluid-dynamics, General, General - FLUENT
January 25, 2023 at 7:16 am
FAQParticipantSometimes, for example in batch mode, we might need to export data in a specific format from Fluent, specify all zones and several scalars. The below example TUI commands can be used for this purpose. To export a tecplot file named “tecfilename” that includes pressure and temperature values at all nodes of the domain, use: fi ex tec tecfilename () pressure temperature q To export a tecplot file named “tecfilename” that includes pressure and temperature values only for the zones named “wall” and “inlet”, use: fi ex tec tecfilename (wall inlet) pressure temperature q Please note that the () are used as delimiters and are important to specify.
- Skewness in ANSYS Meshing
