January 25, 2023 at 7:16 am
FAQParticipantUse the Scheme commands below to ignore the secondary gradient of Heat Flux. It is effective in improving convergence of the energy equation in cases with high skewness of the mesh. For the entire region: (rpsetvar ‘temperature/secondary-gradient? #f) Only for the Wall: /solve/set/expert/use-alternate-formulation-for-wall-temperature? Yes Only for Shell Conduction: (rpsetvar ‘temperature/shell-secondary-gradient? #f) Note the parentheses are required for the input.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
