June 6, 2022 at 8:33 am
FAQParticipantANSYS Forte’s SI engine capability employs both a flame-propagation model (using the G-equation approach) and detailed chemistry. The G-equation determines where the flame resides at each time step and a chemical-equilibrium assumption is used on the flame front. Everywhere else, detailed chemistry is employed. In this way, we can predict knocking from auto-ignition outside of the flame front (e.g., in the “end gas”) due to compression by the flame propagation. Forte’s G-Equation model accommodates multi-component fuels and is fully integrated with Forte’s detailed kinetics solvers.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
