What is the most efficient way to compare results on clip planes for very large (>100M element) cases?
Tagged: 2020 R1, Calculate Variables, ensight, fluid-dynamics, General
March 17, 2023 at 8:58 am
FAQParticipant1. For each geometry a. Load case in SOS (Server of Servers) b. Create clip planes (x,y,z), using plane tool with finite clip extent c. Calculate variables on clips and surfaces d. Save EnSight Case Gold files for clips and surfaces (consider grouping, ie all x clips in one file) with File > Export > Geometric > select Case (Gold) 2. Start a new non-SOS session of EnSight a. Load reduced case files for each geometry (non-SOS) b. Use CaseMapDiff
- Skewness in ANSYS Meshing
