What is the meaning of gamma values >1 and up to the value of 2 in a gamma theta transitional model?
- 1 and up to the value of 2 in a gamma theta transitional model?" target="_blank" rel="nofollow" title="LinkedIn">
- 1 and up to the value of 2 in a gamma theta transitional model?" target="_blank" rel="nofollow" title="whatsapp">
- 1 and up to the value of 2 in a gamma theta transitional model?" target="_blank" rel="nofollow" title="reddit">
- 1 and up to the value of 2 in a gamma theta transitional model?" target="_blank" rel="nofollow" title="facebook">
June 5, 2023 at 7:05 am
FAQParticipantValues of gamma > 1 are used as a correction to the SST model in separation regions. SST tends to overpredict the length of separation and using gamma = 2 introduces some additional production of turbulence and therefore the length of separation is corrected.
- Skewness in ANSYS Meshing
