Tagged: 18, fluent, fluid-dynamics, General - FLUENT, heat-transfer
January 25, 2023 at 7:16 am
FAQParticipantWhen postprocessing a wall that has a thickness but does not have shell conduction enabled, the Temperature… category provides three options: the temperature of the adjacent fluid / solid cells are stored as Static Temperature; the temperature of the wall surface itself is stored as Wall Temperature; and the temperature of the surface that is separated from the fluid / solid cells by the wall thickness is stored as Wall Temperature (Thin).
- Skewness in ANSYS Meshing
