What is the difference between the post-processing variables “Incident Radiation” and “Surface Incident Radiation”?
Tagged: 16, fluent, fluent-post-processing, fluid-dynamics, post-processing
January 25, 2023 at 7:16 am
FAQParticipantThe Incident Radiation is the total radiation energy that arrives at a location per unit time and per unit area. So this is a quantity which is valid within every cell of a cell zone which participates in radiation. The Surface Incident Radiation is the net incoming radiation heat flux on a surface and for that it is only defined on surfaces. For both the unit quantity is heat-flux (W/m^2)
- Skewness in ANSYS Meshing
