Tagged: 18, fluent, fluid-dynamics, Modeling/Setup Advice, Species/Reactions
August 25, 2023 at 12:15 pm
FAQParticipantFluent uses the Gas constant [J / kg / K], Universal Gas constant is the general gas constant [J / Kmol / K]. Note the different dimensions: Gas constant is the Universal Gas constant divided by the molecular weight of the specific gas. The Universal Gas constant in Fluent is defined as 8314.34 [J / Kmol / K].
1. 2043032.pdf
- How do I model humidity in Fluent?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Model setup: Setting up chemical reactions
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
