Tagged: designmodeler, fluid-dynamics, General, Other, Preprocessing: Geometry
March 17, 2023 at 8:58 am
FAQParticipantSweep operation takes a profile and a path to create a solid, surface, line body, or thin-walled feature. Skin/Loft operation takes a series of profiles from different planes to create a solid, surface or thin-walled feature fitting through them.
- Skewness in ANSYS Meshing
