June 6, 2022 at 10:33 am
FAQParticipantPatch dependent meshing uses the same mesh generation method utilized in ANSYS TGrid. A tetra mesh is generated, starting from the outer geometry. Patch dependent meshing is especially effective in cases when the geometry is complicated and accurate mesh generation is needed. However, the mesh may also be finer in areas that are not important in your calculations. Patch independent meshing uses the same mesh generation method utilized in ANSYS ICEMCFD. A tetra mesh is generated, starting from the inside of the mesh generation region. The advantage of patch independent generation is the ability to ignore points within the model that have no relation to your calculation. It is also an effective method to use when working with CAD models of poor quality, possibly saving significant time in mesh generation. However, there is a risk in creating a mesh that does not maintain high fidelity of the geometry.
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS ICEM CFD: Basic Blocking
- How can I create a 2D section from a 3D model in SpaceClaim ?
- What is the difference between patch dependent meshing and patch independent meshing?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
