Tagged: 19, contact, General, mechanical, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantIt is set to On for all the contact types when large deformation is set to Off. In addition, it is always set to On for bonded contacts.
