What is the basis for wet coal combustion? Should the water in the coal to be included in the massflow of the coal or should the massflow be set on a dry basis?
Tagged: 19, BCs & Interfaces, fluent, fluid-dynamics, materials, Species/Reactions
January 25, 2023 at 7:17 am
FAQParticipantThe injection properties for the coal can be set to accept wet or dry injection, independent of the setting in the coal calculator. If the Wet Combustion model setting is activated for the injections in the Set Injection Properties dialog box. the flow-rate of each injection should be entered on a wet basis.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
