Tagged: ansys freeflow, ansys freeflow faqs, coarsening, FAQs, FreeFlow, FreeFlow SPH, SPH, SPH Adaptive Size
May 22, 2026 at 7:32 pm
FAQParticipant
What is SPH Adaptive size coarsening, and how does it work in Ansys FreeFlow?
Coarsening is the process of reducing SPH resolution when refined elements are no longer needed.
Without coarsening, the number of SPH elements would continuously increase, leading to excessive computational cost.Ansys FreeFlow applies automatic coarsening to maintain efficiency.
- Coarsening is performed every 5 solver iterations (fixed behavior)
- Instead of merging many elements at once, the solver merges SPH elements two by two
- This gradual process avoids numerical instabilities and mass loss
Two SPH elements are coarsened only if all three conditions below are satisfied:
- Distance from geometry
The elements must be far enough from any geometry boundary:- Distance > Refinement Distance Factor × Initial SPH Size
This prevents instability near walls.
- Refinement level compatibility
Each SPH element tracks its refinement history.- Coarsening occurs only if the combined refinement count is below the maximum allowed by the refinement level.
- Distance between elements
The two elements must be close enough to each other:- Their distance must be smaller than the average smoothing length
- The smoothing length is computed using the Kernel Distance Factor and the SPH element size.
Access more FAQs and Tips in the page:
- Skewness in ANSYS Meshing
