June 6, 2022 at 8:32 am
FAQParticipantThis warning indicates that a flow related boundary (such as inlet) is in a Solid zone (no fluid flow is solved in the Solid zone). To correct this problem, either modify the boundary condition type for this boundary which is appropriate for a solid zone (e. g. inlet), or change the solid zone type to fluid if it was defined as solid by accident.
- Skewness in ANSYS Meshing
