What is meaning of message: One or more objects may have lost some scoping attachments during the geometry update.
June 6, 2022 at 10:33 am
FAQParticipantUsually, it means that some mesh controls – like the controls that set the surfaces for inflation – may not be applying to the same surfaces as before. It is a note that the associations for mesh controls should be reviewed. (Usually, some surfaces get dropped because their internal nomenclature has changed.)
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- ANSYS ICEM CFD: Basic Blocking
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Fluent: Watertight Geometry Meshing Workflow
- How to Fix the Error: “Mesh Exporter does not Support Overlapping Geometry in Named Selections”?
- How can I create a 2D section from a 3D model in SpaceClaim ?
