June 5, 2023 at 7:04 am
FAQParticipantThis JOINT tolerance is used to check on satisfaction level of Joint constraint. For examples, if it is a universal joint: some of the constraints for node I, J are: UxI = UxJ, UyI = UyJ, UzI = UzJ, During the Newton-Raphson computation, these constraints are ‘exactly” satisfied. If || Ui — Uj || < || JOINT tolerance ||, as a result the solution converges. By default, the JOINT tolerance = 1.0e-7
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
