What is difference in heat flux specified at the wall of a fluid domain and considering solid with the same heat source?
June 6, 2022 at 8:33 am
FAQParticipantWhen a CHT simulation with heat source in the solid is defined, a distribution of the heat flux at the fluid-solid interface is observed according to the temperature gradients between the solid and the fluid domain. This is part of the solution. To get the same results between the simulation with and without considering the solid please write a boundary condition profile at the fluid interface side from the CHT-simulation in ANSYS CFD-Post, load it in ANSYS CFX Pre and use as a Boundary condition at the heated wall of the fluid domain. How to use Boundary condition profile can be found in the ANSYS Documentation> CFX> Modeling Guide>2.9 Profile Boundary Condition.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
