June 5, 2023 at 7:04 am
FAQParticipantThe easiest way to calculate multiple force reactions is to select all boundary conditions or contacts where force reaction will be scoped, drag them to Solution and then release. Force reactions will be automatically created for these boundaries or contacts.
