June 5, 2023 at 7:04 am
FAQ
ParticipantIncorrect contact pairs is generally the case with most thermal analyses in electronic systems due to very thin members in the assembly.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
