March 17, 2023 at 9:01 am
FAQParticipantChange the Settings > Product to “Default.” Academic licensing will not recognize the “Full CFD” or “ANSYS Solvers” product settings. Q: Okay, I changed the product to default, but can now not run prism, the delaunay, t-grid or advancing front methods? A: Most batch processes, meaning processes that run as child processes of med (the main icem gui) cannot read the academic key (aa_mesh) in the 11.0 release version. This will be fixed in the upcoming service pack (11.0 – SP1) or you will be issued a separate key for that process.
