Tagged: 19.2, fluent, fluid-dynamics, General, General - FLUENT
April 5, 2023 at 2:32 pm
FAQParticipantAn alternative way in such case can be to change the two periodic surface types to interfaces. Then create a manual interface using these two surfaces and put ‘Periodic Boundary Condition’ as the condition. Also use the offset values that is shown in the error message when using ‘make-periodic’ command. This should create a non conformal interface with periodic conditions and should work fine.
- Skewness in ANSYS Meshing
