June 19, 2026 at 3:06 am
FAQParticipant
What happens to SPH elements during SPH Adaptive refinement in Ansys FreeFlow?
When an SPH element is refined:
- It is replaced by smaller elements according to the selected refinement level
- The original element is replaced by multiple smaller elements
- The total volume (in 3D) remains unchanged
Example (3D case)
- Consider an SPH element whose size is equal to the SPH size.
- With refinement level 1:
- The new SPH size becomes SPH Size / 2
- The original element is replaced by 8 smaller elements
- Each new SPH element occupies one eighth of the original volume
- With refinement level 2:
- The original element is first subdivided into 8 smaller elements. Each resulting element is then further subdivided into 8 elements. After two levels of refinement, one SPH element is transformed into 64 elements.
- Spacing between elements is reduced accordingly.
This structured refinement ensures numerical stability and consistent element spacing.
Access more FAQs and Tips in the page:
Ansys FreeFlow™ smoothed-particle hydrodynamics (SPH) simulation software
- Skewness in ANSYS Meshing
