Tagged: designmodeler, fluid-dynamics, General, Other, Preprocessing: Geometry
March 17, 2023 at 8:58 am
FAQParticipantThe Mid-Surface feature allows the creation of surface bodies that are midway between existing solid body faces. The resulting surface body(s) have a Thickness property which defines the “thickness” that surface body represents. The faces can be manually selected, or an automatic mode allows you to set a thickness range and then automatically detect matching face pairs. The mid-surface tool is accessed from the menu Tools -> Mid-Surface.
- Skewness in ANSYS Meshing
