Tagged: 2020 R1, Calculate Variables, ensight, fluid-dynamics, General
March 17, 2023 at 8:58 am
FAQParticipantIf the value is found along the normal into the surface – the distance is computed; otherwise the value is supposed to be assigned an Undef_Value = -1.2345e-10. The user has options under the palette > other to specify how Undef value is displayed.
- Skewness in ANSYS Meshing
