What does the following error message issued during an NLAD solution run refer to? Error: Multiple dimensions detected in the model. This is not supported in rezoning.
June 5, 2023 at 7:05 am
FAQParticipantOne possible explanation is re-zoning does not support meshing with elements having an inconsistent DOF set. (i.e. mix of 2D and 3D element types in same model).
