What does the following error message issued during an NLAD solution run refer to? “Error: Multiple dimensions detected in the model.”
June 6, 2022 at 9:58 am
FAQ
ParticipantOne explanation is rezoning does not support meshing with elements having an inconsistent DOF set. (i.e. mix of 2D and 3D element types in same model).
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
