June 5, 2023 at 7:06 am
FAQParticipantThe warning message: Note: Max supported value for env var is 4095 vsetenv … failed is generated by the InfiniBand driver userspace library when an environment variable exceeds the limit of 4095 characters. This warning has no effect on the running job and can safely be ignored until a fix is available.
