What combination of options enables the “Non-Adiabatic Laminar Flame Speed” under the properties tab when solving a partially-premixed, non-adiabatic FGM diffusion flamelet model? I have tried activating and deactivating several different options and nothing seems to ungrey this option through the GUI?
Tagged: 17.2, Flamelet Models, fluent, fluid-dynamics, multiphase, Species/Reactions
January 25, 2023 at 7:17 am
FAQParticipantThe partially premixed mixture properties are calculated by Fluent during the PDF table generation, so this option will only be active once the first PDF has been generated for a partially premixed combustion case. The Non-Adiabatic Laminar Flame Speed is compatible with the Steady Diffusion Flamelet or Chemical Equilibrium State relations, but unavailable for Unsteady Flamelets and Flamelet Generated Manifold (FGM).
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
