What causes the error “At least one contact pair has no elements in it” when using JOINTS ? How to resolve it?
June 6, 2022 at 9:58 am
FAQ
ParticipantThis error is cause due to Scoping to more than one line/surface to define Reference. For an example in a three holes assembly, if two hole edges are scoped as Reference and third hole edge as mobile this error will appear. But Scoping one edge as Reference and other two edges as Mobile will resolve this error.
- ANSYS Mechanical: Node Merge
- ANSYS Mechanical: Node Move
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- What is the difference between shell 63 and shell 181?
- How to use ANSYS Workbench for Merging Mesh Nodes
