What causes that the following error and is there a way to force the run to continue? ‘contact sets empty’
June 5, 2023 at 7:04 am
FAQParticipantThis typically occurs when a small face is defeatured out of the model and no element faces are available to form the contact elements. One can allow the run to continue by setting the variable allow_contact_empty to 1.
