March 17, 2023 at 8:58 am
FAQParticipantThe units of angular velocity in POLYFLOW are rad/s. The only exception to this rule is found in the definition of velocity data in MST (Moving parts motion definition) where the angular velocity is to be given in rpm [revolutions/min] as specified in the POLYDATA menu.
- Skewness in ANSYS Meshing
