June 5, 2023 at 7:05 am
FAQParticipantOne can find the details about different stress results in ANSYS Help file at \ANSYS Documentation -> Mechanical Applications -> Mechanical User’s Guide -> Using results -> Structural Results -> Stress and Strain
