June 5, 2023 at 7:05 am
FAQParticipantExpressions can be used to get alphanumerical values of e. g. a variable at a location like a surface or volume. Equations can be used to define a variable directly but it is preferred to define first an expression and define the variable with this expression.
- Skewness in ANSYS Meshing
