Tagged: 18, Boundaries (Maxwell), Electromagnetics & Electronics, maxwell, Other
September 22, 2023 at 11:02 am
SolutionParticipantIn 2D: Region boundaries: No default boundary conditions, vector potential or balloon is needed. (In electric solver with voltage excitation no boundary condition needed). Boundaries between the objects: So called natural boundary condition is applied by default – normal component of B is continuous over the interface in magnetic solvers, and normal component of D changes by the amount of surface charge density over the interface in electric solvers. In 3D: Region boundaries: So called Neumann boundary condition is applied – H is tangential on the region boundaries in magnetic solvers and E is tangential on the region boundaries in electric solvers. Boundaries between the objects: Same as in 2D.
- EM FAQ: How to export the simulation results/plots of Maxwell?
- EM FAQ: How to quickly fix or heal imported geometry in Maxwell 2D?
- ANSYS Icepak: I get a meshing error – “Warning: no mesh exists for block, body”. How do I fix this?
- EM FAQ: How to define project variables that apply to all designs?
- What are the default boundary conditions in different solvers?
- EM_FAQ: When a DXF file is imported, how can you generate Areas from selected Lines?
- Vacuum Thermal Modeling in ANSYS Icepak
- ANSYS Icepak: How to delete unused materials in a project?
- ANSYS Icepak: O-grid meshing issues
- EM FAQ: How to link the mesh from a static solver to transient solver in Maxwell?
