June 6, 2022 at 8:32 am
FAQParticipantIf you list the periodic interface, you would be able to see those zones in the list. If the areas are not exactly same and there is very small difference then to cover this difference, these extra zones are in the list.
- Skewness in ANSYS Meshing
