What are different options in Mesh Interfaces panel? When to use periodic interface, coupled interface?
August 25, 2023 at 12:16 pm
SolutionParticipantPlease see attached document for solution. Keywords: interface, coupled, periodic
1. 2048996.pdf
- Skewness in ANSYS Meshing
